ECMlink 30psi 16g 3rd gear WOT Log
I do a WOT pull past peak VE, which is 5500-6000rpm. I'll adjust the base fuel pressure on the fpr until AFRatioest=WB, AND BoostEST=map sensor, AND the value used on the mafcomp is zero OR the value use on the SD table is 100, all at this peak VE. When those 3 stars align between 5500-6000, it's done.
I see where you're going with this and it's finally making sense. To clarify, the stock sd table has 99 VE at 4500rpms but you're saying I want peak VE at 5500-6k correct? I was able to get a 3rd gear log today. It has some knock in it but, ignoring that, if I'm understanding things rightly, I should raise fuel pressure a little. Is that right? I'm not sure cause my wbfactor hits 0% right at 5500rpms but my boost est is off by 2psi.
I already started the cruise tuning in the sd table but the wot cells haven't been touched yet.
So far, I've always adjusted fuel pressure with the car off by turning the pump on in link. Per your advice, I slowly turned the fuel pressure up from 43.5psi to 51 (making a pull after each adjustment), and it didn't change my wideband at wot AT ALL ugh LOL.
Went to adjust it with the car running for once and the gauge on the afpr didn't move at all when I pulled the vac line from it, so something's up. There is no liquid in the gauge. I've also noticed that the car used to hold fuel pressure after shutoff (20-25ish psi) but now it drops down to zero. Guess I'll take the afpr apart soon and have a look at it
