Log 3rd gear pull
I think if you could post your actual data rather than the graphs people will have a much easier time interpreting it. Simply go into the converter, and select the palm file. The thing will then spit out the info in excel form, simply post it (without the tabs) and someone will be able to give you a good idea of where to go next.
Sorry here ya go
It looks like toy may be a bit rich and you could use more timing advance under boost. I would try leaning out the SAFC a couple of points from 3K-6K. 02's aren't a very effective indicator but since your timing isn't getting pulled, I doubt that you are knocking. Anyways drop a couple of percentage points and see how the car responds, 5-8 more degrees of advance in the lower rpm's and maybe a point or two in the upper range would be good.
Aloha
Well i went off or RRE site i have about all the supporting mods but my FMIC am still using the Stock SMIC i'am thinkin if i lean anymore i may start pulling my timing i dono ill give it a try.
