3000 gt W/ AWD into a montero
3000GTmontero
Sep 19, 2007
chesapeake, Virginia
So i have a 1997 montero i have this feeling that it might be possible to swap in a 3000 GT engine W/ the AWD trans with the slights amount of easy and fab i have taken a close look at both the V6 montero and the 3000GT motors and transmission and they are very much similar i want to get the most info as i can before i get to involved and come to find out its not possible without spending obscene amounts of money to make the swap possible and two sense is much appreciated. Thank you
Your on the wrong site!! ROFL
Visit www.3si.org and you will find lots of information about the 3000GT/Stealth motor and AWD system. I do know that the motors are more or less the same and should swap in and out. There has been lots of talk about doing it though I don't believe I've heard/seen anyone that has completed the task. The Montero comes with a 3.5L 6g74 motor while the 3/S's come with the 3.0L 6g72. Monteros came with their own AWD systems, so unless you were looking for the grand touring, long gearing 3/S transmission and drivetrain, you shouldn't need to 'fab' anything. Again though, check out 3SI, search around and you will find lots of info. http://www.stealth316.com is also a good place for 3/S information.
i have seen it done once, there was a guy in washington a few years back who had it. good luck
