420A 2gNT Speedometer/odometer issue?
eclipsed123
104
Feb 28, 2009
Newnan, Georgia
I have a 95 eclipse 420a non turbo. Every since I've bought the car the speedometer has never worked and the odometer only moves 1/10 of a mile for about every 20 miles that u drive. I thought it was just the speed sensor. I ended up replacing the whole tranny due to bad syncros. The speedometer/odometer worked for all of 30 miles after that before I had the same issue. I've replaced the gauge cluster, tried 3 different speed sensors, and replaced the wiring pigtail that goes to the sensor. Here is the strange part if I go around a hard right curve the speedometer will work only until I straighten the car back up and then it stops again. Has anyone every had this issue or any idea of what my problem could be?
did you ever get that speed sensor fixed? x2
