420A 2gNT Shifter cables
Gavinrich25
80
Jul 26, 2021
Roanoke, Virginia
Hi guys just wanted to see if anybody knew for sure because I seen no threads on it at all.
Do the avenger shifter cables work in the Eclipse RS?
Here the part number MB910537. If I look it that up in Mitsubishi's warehouse, it comes up but it doesn’t confirm it fits it.
If anybody knows thank you
Looks like they'll fit. Should be exactly the same. Here's the part number for the OEM shifter cables I ordered a couple years ago:
MB910537
The Avenger was a Mitsubishi based vehicle, the non turbo 2g is Chrysler based under the hood, are we sure that those two are compatible?
I pulled the part number from when I ordered mine and it's the same as the part number that he posted for the Avenger. As long as he posted the proper part number they are compatible.
That’s the shifter cables for the 2g manual eclipses right?
Yes, for the non turbo 420a (GS & RS).
