420A 2gNT fuel filter assembly help!
Kyleb2021
97
15
Nov 13, 2021
Lansdale, Pennsylvania
my 1999 mitsubishi eclipse gs 420a non turbo i was wondering if anybody had all the part numbers for theses following things....
Fuel Main Pipe
Connecter
Fuel Filter Gaskets
Eye Bolts
Pressure Regulator
High Pressure Fuel Line
my entire fuel filter and connecters are gone and need to be redone and im having a hard time finding part numbers.
Yep, looks like they have everything you need.
By the way, if you buy a new fuel filter it will come with new crush washers (gaskets) so you don't need to find those separately.
apparently i must be stupid i dont seem to be finding anything but a fuel filter which i already have can u show me what i need. thanks
Fuel main pipe (you meant fuel filler neck, right?)
Fuel pressure regulator. Take a look at your fuel rail and see if that's where yours is. I'm pretty sure your is on the fuel lines under the car.
Fuel Main Pipe
Connecter
Fuel Filter Gaskets
Eye Bolts
Pressure Regulator
now if you don't have the Fuel Main Pipe, which is the feed line to the engine, there are a few ways to go. If its just missing the end of it, get a picture posted up so we can see if repairable or if you need to replace it.
