420A 2gNT Clutch bolts?
Clos_
Apr 28, 2022
Charlotte, North Carolina
So I got this clutch for my 1996 Mitsubishi Eclipse rs (420a) from throtl I was told I needed that flywheel that’s in the picture it’s a 5 speed manual and I was told I need the 4 bolts to bolt on to the clutch im not sure if that’s right or not so i would truly appreciate some help? If it is where could I find those 4 bolts?
So I assume you're doing a manual swap? And that's why you needed the bolts and flexplate? (Yes it's called a flexplate)
If not, the bolts are re-usable
No I’m changing my clutch I had a act clutch before but the act flywheel doesn’t fit my new clutch
The stock setup was modular. Clutch disc, flywheel and pressure plate all riveted together. If you wanted a light flywheel the pieces would come separately like a regular clutch setup.
