Javi4g63
- 0
- Jul 26, 2015
Minooka,
Illinois
Alright fellow dsm'rs, let me start off by saying i bought this car in pieces 97 gst. The shell was not molesting in the cabin. only thing that was removed was the main engine harness and some relays. on other hand the bay had nothing in it except harness from the cabin and fuse box. basically everything was there except the long block and sensors. i got a 98 ecu and engine harness with complete rebuild from top to bottom .20 over pistons, factory t25 turbo. I've never drove the vehicle. i would really appreciate if any one has any type of input big or small to post so anyone with a similar issue could go down this thread to hopefully diagnosed there vehicle. so heres my problems guys my car cranks but doesn't turn over. it doesn't even try. so i started looking for fuel spark and compression. thats really confusing me because I'm getting all those but my spark weakens by the time it make it to the spark plug. I've stuck i screwdriver in the coil with a grounded wire to see if i get spark. i do! :/ some how i get a deep blue spark directly from the coil but doesn't make it to the spark plug. well sometimes its does and sometimes it doest more doesn't then it does. plus when i do the ark is weak:/ i don't know if it could be a ground, sensor or something that has to be plug in in order for the car to start. I'm saying that because all the sensors in the engine bay bolted on the fire wall are not plugged in. there vacuum sensors. posted some pic to see if you guys spot something. ill take more pics of specific locations. please any info will be much appreciated.
