2G 2g with a 1g head.....how do i set timing?
rangerguy
162
4
Dec 10, 2002
Newport, North Carolina
it has an adjustable cas, i know on the 1g their is a connector to ground out the timing to set it to 5 degrees btdc. where or what is the procedure for a 2g?
i have a scan tool and it shows in the live data timing at idle....obviously it fluctuates around with rpms. but assuming it idles steady can i at least get it close?
tia
