2g Wheels and Tires Size Questions [merged] fit fitment
alright thank you.. so lets say i decided to get a wider wheel.. whats the max width i can put without rubbing and what would be a nice sticky tire for up front.. ive tried alot of different stuff from sumitomo HTR+'s and Those RSA's that come stock which suck ass in my opinion..
on my stock 16's i run 235/55/16's goodyears they handle pretty well and got great traction and im a fwd.. they do stick out on the sides a lil but i dont have a problem with it, also they never really rubbed against the wall either. hope this helped you a little
awesome i was hoping someone could tell me from experience if they have ran 235's up front and how they worked.. i need a wider tire like most of you FWD guys and i wanna keep it looking as stock as possible...
I'm running 225 50R16s on stock 94 RX-7 wheels with no problem and I picked up the rims and tires used for 450. I sold the rims I had on the car (Z racing) with brand new tires for 300, so if you look around on you can find them pretty cheap. The 225s made a huge difference over the 205s I had on before. The only problem is that the center caps off the RX-7 wheels will not fit the front rims.
PICS????
235,,Holy Sh1t that seems almost dangerous,,you sure its the stock 6inch wide wheel?
and whoever said 245's on a stock wheel were a good choice, no way in hell would that work out well.
well thats wut was on the rims when i bought the car. I thought the same thing most of you guys were thinking and that theyre too big for that kinda rim but surpisingly its been handling well and the traction is g0od. O in case you were wondering their Goodyear Eagle GT's P235/55r16. Here are some pics also mabye they'll help give you a better visual of what they look like
For the price, yokohama avs es100's are great tires.
I have 225/45/17 on 17x8" wheels.
My apologies in advance, I've tried searching but with 56K it became frustrating.
I just bought some stock 17" 99 gsx wheels. They are 17x7.5 I beleive but could be wrong. Just want to know what the common tire size for these wheels are? I need to buy some tires for them. I'm on Eibach Pro's dropped about 2 inches dont know if that needs to be taken into consideration. Appreciate some feedback! :D
i dont have stock wheels, but im running sumitomo htr+ 205 40 ZR 17's n i love them so much i would never go with any other tire
ive had hankook ventus h2 225 45 ZR 17's n i hated those
i was wanting to know what the widest wheel/tires you could run on a stock suspension 97 talon...i want to go with a 17 inch wheel..but what would be my max tire width before i start to run into problems?
That will depend greatly on the wheels offset.
40mm offset would probably be what you are after. 245 shouldn't be a problem with that offset. More than likely you'll need to roll the rear fenders though. Maybe not with stock suspension, but definitely if you lower it.
The wheel would need to be at least 8" wide to accomodate a 245 tire, so keep that in mind as well.
Read up.
http://www.dsmtuners.com/forums/search.php?searchid=428113
I'm buying a 95 GSX but i LOOOOVE the 5-star 16in. chrome wheels from the 97-99 GST's. Will they fit the 95 GSX? Someone told me 97-99 GSXs have larger rear brakes and required the upgrade to 17in wheels b/c the 16in 5 stars wouldn't fit. Is this true? HEEELLP!!!
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
    • ist dwa
