dsm dork
- 124
- 0
- Nov 3, 2004
Florida
I installed a 2g trans in my 1g car. Is there a difference that I should be aware about other then the mounting plate? Is there also a physical difference in the 1g converter from the 2g converter as I installed a 1g converter in my trans before mounting it all up. Do I need to pull it out and install a 2g converter? I'm sure the lockup with the 2g trans only works with the 2g converter correct? Thanks
