2g Timing tensioner lever bolt broken
emerica12124
40
Apr 18, 2007
Canton, Ohio
Im working on a 98 talon non turbo 2.0L. Timing belt went out. Took it apart found out the tensioner pulley was not attached. The bolt where the hydraulic tensioner pushes up on the tensioner arm that pivots broke. Here is a picture.
So whats your take on this....
Anyboy ever had this problem. Hope the dealer has the bolt.
If that`s a 420A Chrysler engine - I have run into this a few times. Go to a Chrysler dealer & buy the updated complete timing belt retrofit kit (new belt, tensioner, inner & outer covers, updated style tensioner assembly). This new style setup was devised to allieviate this exact problem . . . :talon:
