2g talon only idles
gates6297
Dec 24, 2010
Raton, New Mexico
:banghead:I just bought a 95 talon tsi awd ran good till my dumbass decided to mess with the apexi safc2 in the car because it was always running lean the car is now running at stoch but it only idles when i hit the gas it boggs down and almost dies wont go over 1000rpms! help i dont not know what mods been done to car! Help please:banghead::banghead:
Before you even mess with an SAFC you should get a Wideband at the very minimum. Unplugging the SAFC will not reset the ECU, you need to reset the SAFC to the previous settings or just zeroing everything out. You may have added too much fuel and it bogs down because you are drowning the cylinders. Not knowing the mods to the car then touching the current tuning settings is asking to blow something apart. I recommend going back to the previous setting or at least finding out the injector size, what type of fuel pump, ect.
Ok i will rest the safc and zero everything out and see what happens. And i will contact dealer and see if he can give me the perivouse owners info. hopefully.
zeroed out everything and runs worse! #### im really kicking myself!!!!
What type of car is it? I've seen in some of your other threads that you say its a TSI. Also find out what type of injectors you have and I'll be able to give you general settings for the SAFC.
ITs a 95 talon tsi awd!
Check your MAF and the connection. Also how many Hz does the SAFC say you're flowing? Remember to make sure the SAFC settings say its a Karman sensor, 4 cylinders and the arrow is pointing towards the right. This thread I'm about to link you to will help you with settings and wiring check.
http://www.dsmtuners.com/forums/art...g/354838-how-install-apexi-safc-2g-turbo.html
Well, i guess i should have been more clear. As you put it up there ^^
Yeah LOL, the ECU doesn't really get reprogrammed by the SAFC, just tricked. If he did unplug the SAFC the settings would no longer apply but he also wouldn't get a MAF signal since its being re-routed through the SAFC by cutting the MAF wire and plugging it into the pink and orange ends of the SAFC harness.
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
