7ahmir
- 1
- Mar 30, 2023
Denver,
Colorado
To give some background about two days before this issue occurred I had been going in and removing rust spots below my battery mount and had just finished painting over with some rust prevention paint. Once I was done I placed the battery back in to see if it’ll run, but unfortunately… I had dropped the battery ever so slightly and a corner landed on some wires that run around the engine..
When I had went to plug in my battery and crank over the car for the first time, it decided to turn over as if it were going to start, but immediately died after. At first glance in my head I’m saying, ”alright I’ve definitely F’d up a wire from that.” But while trying to inspect what could be wrong, I wanted to try starting it with the MAF sensor unplugged (I had just replaced it the same day) and lo and behold, it turned over
. I’m fairly new the the 4g63 platform as I’m coming from a 420a Eclipse, but I’ve gone through a few of the forums and done some research on here and dsmtalk, but I haven’t found an answer I find sensible (maybe that’s the problem). Fuel system is priming, spark plugs were just replaced and gapped, new MAF sensor, cleaned my IAC, tried a jump start, and I’m currently about to pull my injectors and check them.
My big question is, are there majors things I’ve overlooked? I plan on checking for boost leaks, but the car ran and drove fine before I started doing rust repairs… I’m worried it’s electrical, but I’m willing to take on the job. Before this I was tracing an idle surge problem, so I had cleaned out the IAC and replaced the MAF sensor, but now this… welcome to DSM life ig
. Also please skip the ridicule I might be stupid but I'm willing to learn!
I should add… it turns over when MAF is unplugged but obviously runs rough.
. I’m fairly new the the 4g63 platform as I’m coming from a 420a Eclipse, but I’ve gone through a few of the forums and done some research on here and dsmtalk, but I haven’t found an answer I find sensible (maybe that’s the problem). Fuel system is priming, spark plugs were just replaced and gapped, new MAF sensor, cleaned my IAC, tried a jump start, and I’m currently about to pull my injectors and check them.My big question is, are there majors things I’ve overlooked? I plan on checking for boost leaks, but the car ran and drove fine before I started doing rust repairs… I’m worried it’s electrical, but I’m willing to take on the job. Before this I was tracing an idle surge problem, so I had cleaned out the IAC and replaced the MAF sensor, but now this… welcome to DSM life ig
. Also please skip the ridicule I might be stupid but I'm willing to learn! I should add… it turns over when MAF is unplugged but obviously runs rough.
. You'll have a very spirited driver around that level with a 16g.
