2g spyder roof diagram
SilverSonic105
Jun 16, 2011
Philadelphia, Pennsylvania
Hello, I'm sorry to be a bother but I can't seem to find this, would someone be able to point me in the direction of a diagram for the roof/cover for the spyder?
I would like to take it apart, repair or remake it, and put it back together, but I would feel safer doing that if I had a diagram to show how it should properly be put together.:pray:
It has a couple spots that were patched at some point, looks a little raggedy, but the main issue is I have bad water leaks :( Mostly along the edges so I want to try to understand how it should function so I know how to address the issue. From my perspective it looks fine, but it obviously isn't because water pours in from the driver side and passenger side.
If you have leaks from the edges, the seals might be shot. Tops get expensive quick!
