2G 2g Shifter Rebuild Kit?
danielsl1999gsx
847
93
Jun 5, 2009
los angles, California
My shifter assembly has some play in it and I want to "rebuild" to eliminate the slop. Does anyone know of a kit for these or have every part number needed to make this shifter like new? Im trying to stiffen up the assembly for precise and consistent shifts. I already have solid aluminum shifter base bushings, brass shifter cable bushings, and the RRE solid aluminum shifter cable bracket bushing installed. Only thing left to fix is my shifter assembly. Any help would be great, thanks guys.
My transmission is a brand new TRE stage three unit so im assuming he took care of the select lever, but ill check that out as well!
  • Wanted 6 bolt NT water pipe
    • chrisman287
