where can I get shifter rebuild kit!?
I guess a kit could be helpful, but all you really need is a new set of plastic bushings and a Symborski kit to get the shifter into better-than-new shape. The plastic bushings get worn out over time and do need to be replaced. The rubber bushings that hold down the baseplate just simply sucked from the get go. Pull the shifter out, take it apart, clean and lightly grease everything while installing the part of the Symborski kit that goes inside the shifter, put it all together with the new plastic bushings and torque stuff down. Put the baseplate back in with the metal bushings.
