Resolved 2G Random connector?
jdm9221
125
5
Apr 10, 2017
Osceola, Indiana
First off my car is a 97 gsx with a 6 bolt block and 7 bolt head. Recently the car has had a weird idle so I started checking for vacuum leaks and instead found a sensor that i cannot figure out where it goes. Is this because I have a 6 bolt bottom end? It seems like it should plug ion somewhere to the head and it has a white wire that connects it to I believe the cam angle sensor. I attached a picture, the white line is the two connectors together and the blue is the random plug. Thanks in advance
Its probably the plug for the original cam sensor
Solution
That is the plug for the 2g cam angle sensor you have there and it appears it was jumpered into a 1g green top cam angle sensor to remove the need for the crank angle sensor that comes in the 2gs. The idle issue is probably boost leaks but that connector needs to be wrapped and secured instead of dangling.
Check your vacuum lines first that is the cheapest route also check your line running to the brake booster .. It can get oil soaked and crack. Also double check your throttle stop on the throttle body and throttle cable tension. You want to eliminate as many easy things as possible before you go to Iac,tps or maf.
i would also verify your base timing is at 5 degrees if you haven't already. i bought my 6 bolt swap about 15 degrees advanced at base with a wild tune and my idle was horrible
  • For sale 2g 2G 7 Bolt Lower Timing Cover
    2G 7 Bolt Lower Timing Cover $80 + shipping & paypal fees* there are a few flaws ( pictured )...
  • For sale 2g 2G Manual Shifter Cables ( including NEW bronze bushings )
    2G Manual Shifter Cables $90 + shipping & paypal fees* I will be including NEW bronze bushings...
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
