1G 2G PROPORTIONING VALVE ON 1G?
ESLA
Mar 17, 2014
Rotterdam, Europe
HELLO NEED HELP...
Does anyone know if a 2g NON ABS proportion valve can be used on a 1993 1G AWD GSX to delete the ABS system? I have looked everywhere online including Youtube for the information but can't find any information on this anywhere.
Thank you in advance
I want to say they CAN but some of the ports are 90° off of what the 2g are and the brake biasing seems to be different
You'd have to bend some of the lines
Hopefully another member can chime in and verify
@Anfurnyy Thank you for your fast reply and help, I will be making new lines anyway so that would not be a problem. I just need to know if the 2g one will do the same work as a 1g version will do, pressure wise?
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
    • ist dwa
