Resolved 2g gsx rear sway bar links
T bags
212
142
Apr 9, 2022
Newark, New Jersey
Before I saws all these things off anyone else know the trick for these? It seems to be a 14mm on both the nit and spammer but why are they so frozen? I can see these link time traveling back to 7/96🥸
Solution
Map gas and the impact driver to the rescue. That 14mm inside bolt is a burden to reach so I used a slim needle nose vice grip from husky
Might have to get some new vice grips cause mines are rounding off the flange side and the 14mm nut is frozen shut. I’m starting to lean on these items being oem
Solution
had some more downtime so we painted the sway bar and primered the rear calipers
Multiple photos
Nice weather so we updated the suspension to yonaka coil overs and stp brake rotors, waiting on the pads also this caliper paint took like three coats of goodness
Finally done with the rears
Nice drop compared to the eibach pro kit with agx
