2g gsx 98 ACT Clutch
jason6989
Apr 21, 2013
Manama, Arizona
Looking for the range of 350hp , would you recommend ACT III Racing HD 2300LBS XTREME Pressure Plate
Stage III 6 Puck Ceramic *MIBA* Sprung Racing Disc.
I have read some reviews of DSM guys breaking the pressure plate fingers..
Any suggestions ?
act 2300 is a good PP to start with just make sure you dont use a 2700 if you are a 7 bolt on stock internals as you might crank walk. As far as the 6 puck disk, I had one on my G35 and it was great, just took some getting used to. Breaking PP fingers is relatively uncommon, or atleast ive never had that happen in any car i have had.
I've read that for stock and daily driving, the act 2100 is the way to go or act 2600. Also get a oem throw out bearing, they tend to be more quality superior compared to aftermarket ones.
ACT will work just fine. I have used ACT since 2005. I have never had an issue with the clutches or pressure plates. I would agree with used a new OEM throwout bearing. I have had two ACT bearings nearly split in half. Make sure to account for flywheel resurfacing (I would recommend staying with the OEM flywheel). If you can budget for it, go for a new OEM fork and pivot ball as well.
