2G GST Caliper Bracket -vs- 1G Caliper Bracket
90turbotsi
244
4
Sep 15, 2002
Owings Mills, Maryland
I have a 2G GST caliper thats in good shape but one of the bolts is all messed up and will not come out (Ive already put too much time into this). Im pretty sure that the 90-92 AWD and the 90-99 FWD cars use the same caliper and bracket (well the 2G calipers have banjo fittings instead of screw in, but yea) So I wanted to verify that the brackets would be the same and I can use one of my many single piston caliper brackets (from upgrades), cut the damn bolt head off and ditch the old bracket.
thanks
*** Bolts are different (the bolts that the caliper slides on) the 1G is smaller then the 2G ones. If you have the bracket and the 1G bolts it will bolt up fine. ***
In case anyone else wants to know
