Caliper bracket
68442
639
5
Oct 14, 2007
Des Moines, Iowa
It appears I keep getting the wrong parts. 97 gsx, front caliper bracket. The one on the car and the one I got from advance are different, can anyone tell which one is correct??? The one on the car is a little bigger.
Thanks
I have my OEM 2G GSX calipers and brakets lying on the floor. From the photo you took mine looks the same. Take some measurements and some more photos and I'll compare what I have.
The one that came off your GSX is the right part (because it is directly off the car). Why are you buying new brakets?
Mounting hole to slider hole 8mm, store 7mm. Mounting holes 14mms across, store 14mm. Outer edge of each slider hole about 8 inches, store little over 7 inches. If you need more pictures let me know. One of the pins is broken off in the hole, fused solid like everything else on the front end:notgood:
