2g gauge in center vent
Synapses said:
Are those pro sport gauges ? :D
I think so ya -- they extreamly cheep'o ones from ebay -
I really like how they look - but the EGT gauge it total crap
Thanks guys --
yeah i still have a/c - a vent on each door,the defrost vents and the floor vents are more then enough to maintain temp.
The Gauge it self is fine.. the probe is junk.
It does have a 1 year warrenty , so you can keep getting it replaced.
I've seen sites selling almost that exact same bezel that you posted above. I think the difference is that the gauges in yours looks tilted toward the driver.
Can I have your autograph?
Seriously though, that is sick looking. I'm thinking about doing it now.
I don't have the one that holds a profec, but I bought my dual gauge pod from extremepsi a couple weeks ago. I've got two 60mm gauges in there now, looks and fits great!
How do you use it? Just lay it over the stock piece and heat it up??
I took the stock air vent piece and had to use the dremel took to grind it down. The piece that separates the two vents has an arc to it that's why. The I used a dremel to cut out the holes for the buttons and I used gorilla glue to glue the cf sheet to the plastic center vent structure. I would remove the plastic pieces in the dash so when you turn on your heat it doesn't blow into this causing the glue to heat up.
haha, it's installed in my car already which is in my buddy's garage a couple miles away. And that's the only pic I have of it so far. But if it's any help, it has 4 screw mounts on the back where you attach the sensor/button clusters. I'll try and remember to get a pic next time I'm out working on the car if you want.
PS, my whole gauge pod cost like 20 bucks, same as just the small piece of carbon fiber alone in that link. Nowhere near $50.
