- Year
- 1999
- Model/Trim
- Mitsubishi Eclipse GSX
- Transmission Type
- Manual
- Mods-Bolt-on
- Denso 660 injectors,
Walbro 255 lph rewired,
NGK plugs,
Buschur Racing COP,
JMFab Exhaust Manifold Heat Shield,
Ported EVO III Exhaust Manifold,
Ported EVO III O2 Housing,
EVO III O2 Gasket,
FIAV Bypass Plate,
FFWD FPR Set-up W/ SS Feed and Return lines,
APEXi FMIC,
Greddy hardpipes,
RSR downpipe 3",
HKS Hyper exh.,
HKS SSQV blow off w/ recirculation,
Greddy Profec B boost contr.,
Greddy turbo timer,
Greddy EGT,
Greddy peak/ hold temp. gauge,
Autometer boost gauge,
T3/T4 50 trim,
SS oil line,
Prothane Full Motor Mount Kit,
Shifter Plate Mod,
Under Hood Shifter Mod,
B&M Short shift,
MOMO Shift Knob
- Mods-Engine
- HKS DSM 4G63 272 Cams,
HKS Fine Tune Purple Kevlar Timing Belt,
HKS DSM 4G63 Adjustable Cam Gears,
HKS 4G63 Spring and TI Retainer Kit,
APR 7-Bolt Head Studs,
Cometic Metal Head Gasket,
Balance Shaft Eliminator Kit,
BG Syncro Shift II,
Royal Purple synthetic motor oil (10W30)
- Mods-EMS & Logging
- DSMlink,
95 Eprom ECU,
IBM Thinkpad,
AEM Wideband 02,
3 Bar GM MAP Sensor w/pigtail,
- Mods-Drivetrain
- PTT Twin Disc Clutch Kit,
Complete SS Clutch Line Master-Slave
- Mods-Handling
- Road/Race Front Upper Strut Tower Stress,
Road/Race Rear Strut Tower Stress Bar,
Road/Race Front Lower Stress Bar,
Road/Race Camber Correction Kit Rear,
Prothane Full Suspension Bushing Kit,
RM Sway Bars,
JIC FLT-A2 Coilovers / With John Mueller Set-Up
- Parts Wishlist
- FFWD 2.3 coming
- 1/4 Mile E/T
- 0.000
- 1/4 Mile MPH
- 0.000
- 1/8 Mile E/T
- 0.000
- 1/8 Mile MPH
- 0.000
- 60' Time
- 0.000
- Dyno TQ
- 0.0 lb/ft
