Resolved 2G Front Crossmember bolt sizes
GSXRunner
160
38
Feb 24, 2013
Queens, New York
Hello everyone, I just joined here and this is my first post.
I just replaced the clutch on my 95 GSX and have been bolting everything back together. Working out side in the cold (including snow) I have mixed up/misplaced bolts. I need to know the bolt sizes for the two bolts that hold the front of the cross-member to the radiator support.
Thanks,
JJ
I believe he is looking for these... MB176061 . If its the same as the original thread anyway. I myself just tried to order new oem ones and could not find any. Thought I had some lined up from amayama but after I ordered them they cancelled that item on the order and slapped it with the good ol out of production cause. So, I had my original ones media blasted and then re-zinc coated and all good to go now. May be the best bet with these unless someone else has another option they know of.
These?
yes sir Thank you Steve.
your right you cant order the actual bolt, but you cn order the collar, the Rubber grommet, and the washer/seat. i just drilled the collar out to slide over a 1/2 inch/1.75 bolt.
Did you re-tap the inner threads to accept the 1.75 bolt or did you force screw it on?
EDIT: Doesn't matter. I ended up cleaning the threads with a Metric M12x1.25 tap then got the bolts up nice and tight at 88Nm.
