2g Engine won't start. Need help
supermanjedi69
Jul 31, 2007
Lake Orion, Michigan
I have a 97 GSX and it won't start. The car has been sitting for a little over 9 months. I had the engine rebuilt and tuned before I parked it and it ran perfectly. I drove the car from Ga all the way to MI with no problems. I even drove it around in MI for a week or two after and still had no problems. I came home on leave and replaced the battery and the car won't start. All the lights come on and everything works electricly but when I try to start the car it does nothing and everything turns off. I have checked all the wires and the battery terminals. I checked the starter and it was good. I have also checked all the fuses and still no luck. I would appreciate any help.
If it does nothing when you try to start it and everything dies then it's most likely that your terminal connections are loose or need to be replaced.
check the resistance of the pos and neg wires to the battery with them disconnected usaully if everything dies wen u do that there is a bad connection
