Engine turn but won't start. Need HELP!!
ECLEVO4G
117
Aug 30, 2007
Stone mountain, Georgia
I just dropped a new engine in 98 GSX that my partners and I rebuilt. I have 1g head, cams, cam gears, pistons, rods, etc..... My car won't start for anything but the engine rotates like and sounds like it want to start but it just won't.
1. I am getting fuel
2. new battery and starter
3. I am getting spark
4. CAS is wired correctly
5. Timing is on point did it over 5 times
What could be the reason and I know it's probably billion reasons but I will go through each one.
Check spark at the PLUGS. 99% of people check it at the wires. Just because you have it at the wire doesn't mean it is getting through the plugs though.
Check the compression of it.
Check to see if the injectors are opening. You could be getting fuel to the rail but if they don't open it won't matter how much fuel you are getting at the rail. You can check them by listening to them to see if they click.
Is this a 6 bolt that you put in?
Its 7bolt engine with a 1g head on it.
Somebody correct me if I'm wrong, but I think your supposed to swap the plug wires when using a 1g cas on a 2g.
well you have spark and fuel,you missed something.....the firing order is off.
check everything and recheck,there is no reason it souldn't start if its wired up right.
i know I have rewired everything 3 times over, redid the timing 4 times, making sure everything is connected. Could I hook diagnostic tool to my car see if it will shoot out codes to let me know whats wrong with it, even though it is running????????
stupid question but you do have all of the sensors plugged in right? And i mean all of them. Because i know i forgot to plug in my crank sensor and my maf before and had the same problem.
How do the spark plugs look? Are they gaped correctly? Did you check to see if they are sparking(the spark plugs)?
if they are really really black i would recommend replacing them. And also double check the wiring for the cas. And i know you have checked it several times but check the timing again. And if you would like post some pictures of the timing marks for the cams and crank. Let some other people see them and go from there.
showimage.php
what does this go to??????
showimage.php
what is this and what else connects to it??
Not Connected - what is this? DSMtuners Gallery
    • The_Partout_Spot
    • The_Partout_Spot
  • For sale Garage clean out
    • 92GSXtacy
  • For sale 4G63 Griffin intercooler cores
    Griffin intercooler cores. Top to bottom flow. High cfm and heat transfer. 24x8x2.75 and...
  • Wanted wtb black 2g dashboard
    Looking to buy a 2g black dashboard. Located in southern california but willing to travel.
    • randizzle420
