2G Eclipse GST Spark plug question.
Styxyr
273
Apr 1, 2012
Searcy, Arkansas
Needing to buy new plugs and wanted to know what people recommend and why they recommend that one. Currently boosting 18 PSI. I heard NGK BPR6ES were good?
Edit: Also not sure if this is in the correct forum. Didn't know where spark plugs fit in xD
I run a BPR7ES, but I'm making the switch to a colder plug for a FP Black. It all depends on your setup, and if you're having ignition breakup.
The main reason for changing them is the ones I recently bought from oreillys (there recommendation) were autolites that they gauged way to far off. only been in for 2 days and it runs horribly. so I need it fixed as it's my daily driver.
I would go with the BPR7eS since your running a larger then stock turbo and boost, gapped at .028
I'll get the BPR7ES, thanks everyone!
Ya at stock I got the BPR6ES and after I installed them my car ran perfect! had a lot of hiccups and such before when opening the throttle
Yeah. mine is just running poorly and I can't boost. just starts kicking and missfires like crazy. just got 3.....autozone only had 3 LOL 4th will be in later today.
