2G Drop Engineering coilovers?
dsmcrzy
1,638
368
Dec 20, 2009
Trenton, Ohio
Hey guys I came a cross a set of Drop Engineering coilovers for a 2G. I searched their site and can't seem to find them on there. I did a google search for these and nothing came up for a DSM application (only 240sx, Honda, ect)
Has anyone else tried these? Or heard of them? Below are the specs off the ad.
Looking to put these on my N/T if try are worth it.
Thanks for any help guys.
Drop Engineering Street Function Pro Sport Racing Coilovers 95-99 Eclipse/talon
Part Number: DC-ECL-95
Information:
The Drop Engineering 95-99 Mitsubishi Eclipse Coilover Kit is precision manufactured utilizing state-of-the-art materials and hardware to provide the highest levels of performance. Each system has flawless bolt-on installation and is backed by an excellent 1 year warranty.
All Drop Engineering Coilover Kits feature pillowball upper mounts with mono inverted tube shocks. Rubber dust covers keep the dampers protected and working at their best. Ride height is fully and easily adjustable with the included spanner wrenches. An 8kg front and 6kg rear spring rates make for an aggressive setup perfect for any modded Eclipse.
Includes:
- 4 x Coilovers (2 x front, 2 x rear)
- 1 x pair of spanner wrenches
- 1 year warranty
Tech Specs:
- Pillowball Upper Mounts
- 8kg Front and 6kg Rear Spring Rates
- Adjustable Ride Height From 1"-4"
- Mono Inverted Tube Shock with Dustboot
Note: Professional installation recommended (instructions not included)
Applications:
- 1995-1999 Mitsubishi Eclipse
Warranty:
Drop Engineering (DE), warrants all of its products under its "no questions asked" 1 year warranty policy. Regardless of the defect in product, Drop Engineering will replace the original product. Warranty claims must be accompanied by the original sales receipt from an authorized dealer.
A trained professional should install all DE products. Any issues with compatibility or installation should be addressed before attempting to install the product.
The purchaser's remedy for breach of this limited warranty, exclusive of all other remedies provided by law, is expressly limited to repair or replacement of any part or parts. All products returned for warranty consideration must be returned to DE with all transportation expenses prepaid. DE shall not be responsible for damages to its product or injury to persons using the product. DE shall not be responsible for injury or harm to persons or property caused by persons or vehicles using our products.
Considering 2G's use shocks instead of McStruts (which aren't usually inverted, would probably give some mounting issues! ;) ) I'm going to hazard a guess that they're re labled K-Sport/Megan/D2/etc whatever useless junk, and I'll double my wager if they're from 800-1200 USD.
Here is the eBay item number for them- 221156731907. They look nice and they sell other Drop Engineering products. I just can't find any info about them on a DSM.
A pillowball top, but the spring still rests against the plate? That's seriously weird, but it does suggest that they aren't just the standard crud in green.
Too bad you didn't word this to say you'd double if they're under $1200 as they're $545.99 on Buy It Now LOL
I was confused by that too. Would you say they're still crud, just not the standard crud we normally see? I'd be surprised if they're anything decent at the price they're being sold at. I'm also not a fan of their spring combo, but that seems to go for a lot of the coilover setups out there.
I won't be using these coilover for anything more than some spirited driving. There are no tracks around here that I know of that have track days.
I would love to get the know yellow group buy but I would never use those to any extent. Right now I have the stock kyb's with tein lowering springs. Needless to say the struts are starting to die. I was looking for a cost effective solution that would allow me to set the ride height where I want it and also improve handling.
I know the Megan ez coilovers are only a little more and at least I can find reviews on them. I just know people use Drop's engine mounts and they have a decent reputation.
Brian where could I get that GC combo? I have looked for it before but had troubles finding out about it. I really want a quality product at a decent price for what I will be using it for.
Have you actually looked?
NHMS
New Hampshire Motor Sports is a little over an hour away and they have plenty of events with COM, BMWCCA, Porsche Club, etc.
There's also Limerock Park in CT that also has a ton of events that you can go to.
COM Sports Car Club
You can also go over to FT Devens and do an autocross.
I have but I couldn't find a list of event and registration like the com one you posted.
Thank you for that I will def look into it!!
Believe me, it's an incredible amount of fun. :)
I'll probably be at every regional event next year!
Just to close the loop on this I decided against getting the DE coilovers. Instead I ponied up the extra $100 and got the koni yellows. For now I will just use the tein s tech springs that I have untill I am ready to get the ground control set up.
Thanks for the help Brian!
