2g cruise control delete...
All you need is a non-cruise cable. Or you can just unhooked the cruise cable from the box and remove the box by the fuse box. Clean it up a lot.
You can use a 2g non turbo 420 throttle cable with no cruise control of course. They are easier to find than a non cruise control 2g 4g63 one if they even had that option from the factory. Go to a junk yard, Im sure you will see a ton of 2g eclipses there and almost all of them will be non turbo ones. Just keep looking until you find a throttle cable w/o C.C and take it out.
There only like $45 JNZ tuning. You might spend $20 at a junkyard but atleast with JNZ you will be getting a new one.
I'm not sure if the pedal end of the cable would fit a 2G but a Mirage cable will work on the throttle body end as well as having the right adjustment bracket. Most Mirages don't have cruise and are easy to find in the junkyard.
What do u mean by unhooking the cable from the box and removing the box by the fuse box? Would u still new a. Non cruise cable? I want my engine bay as clean as possible so the less in their the better
I removed the part today by the battary and fuse box. Now I need to figure out how to remove the box on the firewall that has the always in the way hard cable, that runs across the intake and fuel rail.
