Cruise Control Delete on 1990 TSi
BOOSTIN21
413
3
Sep 22, 2003
Cedarburg, Wisconsin
I know these threads are all over the place for 1g's but the 1gb's are differant than the 1ga's as far as C/C location goesi have my C/C box out and the main throttle cable is still in the firewall i know i should find a car with no C/C from that generation but it's a hard find around here and i have looked many times at local junkyards i was just wondering if there was a way around it without finding a non-C/C vehicle.
Why not just order a non-CC throttle cable from one of the vendors? Mine was pretty worn out anyway.. so figured a good time to replace.
Pretty simple to install... just follow the old line from the TB thru the firewall to the go-pedal lever.
Would you tell me the part number of 1g non cruise-throttle cable? I need to make sure I get the correct one.
Thanks in advance.
a 1g non cc trhottel cable is a 1g non cc throttle cable. There is only one so its kinda hard to get the wrong one. Mitsubishi graveyard sells tehm new for about 40 bux or so. But you coudl probably get one off a 1.8 liter dsm at a junk yard for 5-10.
