2g coil relocation(similar to jm fabs bracket)
I used a 2g coil There are four bolt spots.Bend the two down like the others so there all facing same way.Your bending these to mount the transistor here.Now you need to drill out one bolt hole.The one on the bottom when coils face up for plug wires use washers on both sides.This will be on the side where you did NOT bend.I mount the coil where one of the ac bracket bolt would have been(use red loctite).You want the coils facing up so all this should be prety sraiht forward.I will have pics up very soon.I also did this on a 6bolt with accel wires.This also swaps the coils for 6bolt set up.1-4 on first coil 2-3 on the next
pics in my gallery i cant get them in here.
