General 2g base timing
nice97civic
442
51
Jan 29, 2004
lancaster, Pennsylvania
Short story is having knock issues at very modest afr on pump gas. Turns out my base timing is set as the picture shows. Should I be adjusting this in link to get to 5* base?
If you still have the 2g cas you cannot adjust it. I have seen them vary some from machine work but i don't thing that far off before. So with car idling and timing pin grounded in ecm link its idling at TDC for ignition timing? I would almost wonder if you are not off a tooth some where on timing. I usually check it then just remember and figure it into it when tuning. So say it was to be at 3 deg instead of 5. Then what ever ecm link says i know its really 2 deg less ignition timing.
I just checked the timing with ecmlink and timing grounded and was reading 5* so seems like things are okay. I'm grasping at straws at this point to explain the knock I'm seeing. I'll send some logs over.
