2G AWD trunk pieces
2GturboTALON
607
6
Nov 26, 2002
St. Peters, Missouri
I have been having issues with the wooden trunk mats in my car falling apart. I have just learned in my car i should have two black trim pieces to hold the mat up higher. I previously had a fwd dsm so didn't realize it was needed. Does anyone know where these pieces can be found ?
Check DSMGraveyard (used, nice and cheap) and JNZTuning (new, pricey probably).
Hit your local wrecking yard. Its also possible that you may be able to find a way to set it up like the ones that didnt have those plastic pieces. One other idea would be to get your busted trunk board and use it as a template to cut a new one out of something a little stiffer like MDF wood.
I have those. I took mine out and custom cut a piece of inch thick like mdf board for a floor. Its sits lower and is more sturdy.
