2g awd fuel pump upgrade questions
bruce tis
Oct 29, 2007
Carrollton, Texas
hey guys. me and my buddy jared are gonna put a walboro 255 fuel pump in my 98 tsi awd. we got to the pump and got the tubes off, drained the engine started the motor, everything, but we've got some questions:
1. how do we unscrew the thing that needs the 14 and 19 wrenches?
2. how do we get the white cap thing off? it is like welded on!
thanks guys, we're gonna get back into it today after work, so we'll be back with questions. thanks
while your at it, i woud re-wire your fuel pump as well. after i installed my 255 everytime i hit my brakes i could hear the pump drop in voltage, and come back up when i let off. after the re-wire the pump stays at full voltage all of the time.
we tried to unscrew it, but the problem is that when we try to unscrew it it torques the fuel line and i dont want to break it off. it wont looosen no matter what we do and we just seem to mess up the pipe more and more as we try to fix it. need advice.
Soak that fitting with a can or two of PB Blaster over the next few days. If that doesn't do it then you may very well have to unfortunately buy another entire fuel pump assembly (either new or used). Usually that fitting is fairly tough to get off for any of us, but if the pipe/fitting is torquing as much as it looks, then there's not much else you can do. :( I'm assuming you're using a 19mm wrench in conjunction with the 14mm wrench, right? If not, you definitely need to do so.
