2G Upgrade the fuel pump?
Eclipse98_RS
233
Jul 15, 2006
Otsego, Minnesota
These are my current mods. I just bought this car and want to know if i need to upgrade the fuel pump. I want to run 14-15 PSI. Can this be done with what i have? Also if need be point out anything else i might need. Thanks for the help
T3/T4 50trim
turbonetics manifold
tial 38mm wastegate
turbonetics boost controller
2.5” Turbo back exhaust
Precision FMIC
Custom Intercooler piping
Injen Intake modded to 3"
550 Injectors
Apexi s-afc II
Act 2100 clutch
Symborski shifter bushings
Hks ssqv Blow off valve
A-pillar 3 gauge pod
Boost gauge
EGT gauge
Air/fuel ratio Gauge
Alpine 3 disk in-dash changer
17" Motegi Mr-7 Rims
Powerslot slotted rotors
New Transmission
Yea you are def going to need a 255 fuel pump so you can pump enough gas to handle all this power. Especially with that 50trim. And i would also possibly upgrade your injectors the 550s may not be enough. With the bigger injectors youd be able to raise the boost even a good amount more than that. Do you have any internals done? Some HKS 272s wouldnt be a bad idea either. Is this your DD?
Not too sure if there are any other mods than that done. Yes it will be my daily driver for about a month - month and a half and then itll be garaged. Right now its at around stock boost. The MBC is off but i was gonna hook it up. Any recomendations on what kinda boost i should run right now? maybe like 10-11 PSI with what i have now?
any recomendations on the fuel pump? the walbro 255LP is what most people seem to use. Just wondering if i should go with the HP or not?
the walbro is fine (it just makes some noise) i went with the supra pump, althought it required some modification I was extremly happy with it, very little noise and great performance, i could run at 19 psi fine and i only have 550 injectors, but you should still consider upgrading, i KNow that i am.
anyone have any thoughts on what kinda boost i should run?
Why close the thread so soon? To answer your question about boost levels, you should probably be good around 10psi, but i wouldn't go much over that until you get that new fuel pump in and maybe some injectors as well. It's better to take it easy for a while until your car is ready to take a little more boost.
