2g awd camber
geno414
440
4
Jan 13, 2011
Milwaukee, Wisconsin
Hey OK so i lowered my eagle talon awd with a 2" drop and my back camber is messed up the top wheels toe in bad is there a way you can adjust this thought the 1g could does the 2g have this or do i need a camber kit ??if i need a camber kit can i have a link to buy it i can't find any at all only for stupid civics :cry: . can some one help out ??
^^^ Pretty much nailed it on the head. There really isnt an adjustable camber on these cars. The fronts you have a couple options. One of the links provided, or there is an Ingalls front camber kit. I believe those go from -75* to +1*.
Rears isnt much better. Majority of people just use the shim method. Such as the second link provided!
Everything I linked in the first post pertains to the rear camber. The RRE one is $40 or there is a custom one you can make with longer bolts and flat washers.
As per your last post, does it have negative camber or is it toed in? They are two different things.
Joel
The rear toe is adjustable with a cammed bolt.
Nice try (to help), but this guy is using the term "toed in" for camber. Given his proven inability to search, the odds of teaching him the correct terms for alignments is rather low. I'd let Darwin take care of this one.
Which one is the issue?
As jtoby said, it sounds like you're using the "toe" term for a camber issue.
i have negative camber then so all i need to do is thos bolts ?? and washers there is no kit in that link to buy i would have to go to the hard were store then ?
If you're cheap, go with strong bolts (Grade 8.8 or higher) and washers. If you're willing to spend some money, the Ingalls rear camber kit is a nice piece and very easy to adjust. This one will probably be better suited than the +/- 1° kit.
EXTREME PSI : Your #1 Source for In Stock Performance Parts
Then make sure you get a full alignment.
