1g awd rear camber correction?
Nekoni
246
Apr 17, 2008
Iowa City, Iowa
I'm just wondering what all is available for me when it comes to rear camber correction. I already have eccentric camber bushings but the nut is frozen on those and I'm going to have to bust the thing apart, so I'm trying to find something that gives me more adjustability. I've already seen the Ingall control arms and I'm goina say I'm not a huge fan of them. They look fairly thin and even though my car is low hp, it still has sticky tires for road racing and those look like they will bend with ease with how I treat the car around corners.
Wondering if there are any more options available or if I'll have to make something myself.
Thanks!
It's not lowered, it just gets adjusted differently for track driving vs. street driving. When I finish removing a bit more weight I'll measure to see what kind of a drop will work best with the geometry of the control arms (I'm guessing only about an inch or so, if that).
Do you have a link for the DMEs?
If your not going to lower it right away and are just looking to fix the factory adjustment here are the part numbers for the rear eccentrics and hardware.
MB515167 - Bolt
MB303958 - Nut
MB111440 - Eccentric Plate
MS450045 - Lock Washer
They're a pain to get out. Mine were seized despite years (yes years) of soaking them in PB every time I had the car up. I finally ended up cutting them out with a sawz-all. If you,re careful with the sawz-all you can get them out without damaging the arm but you'll probably have to replace the bushings. If you need more adjustment then what the factory eccentrics give you you can try the DME kit EXTREME PSI : Your #1 Source for In Stock Performance Parts - DME Rear Camber Adjustment Kit : Mitsubishi Ecipse 90-94 AWD
Thanks!
I have Ingalls on my car, some e-bay stores sell them. I have it on my recently bought 92 GSX with H&R springs. I don't know about adjusting them so I just went to a local shop. BTW, don't slam your car to the ground, they're heavy enough as it is and you don't want to bust up your shocks. If you like tackling corners or canyon driving and occasional auto-x then just go with a coilover set-up.
Or you could invest on a rear adjustable camber plates though most aftermarket parts for the rear of the AWD are a complete set-up from shocks to coilovers to camber plates. If I'm correct, megan racing has them.
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
