pei_dsm
- 0
- Jul 3, 2009
Charlottetown,
PE, Canada
I had some eccentric washers at home that fit perfectly length wise for my upper control arm bushing, except were 4mm larger than the hole in the energy suspension bushings. Washers are 26.5mm wide so I drilled the bushing out to 25.5 with a Forstner bit (1" bit). Viced the washers in and am enjoying a larger range of camber adjustment. Anyone think shaving 3mm from the inside of the bushing would have any impact on it?
For anyone that doesnt know what an accentric washer is, it looks like
where the mouth is the hole the bolt goes through.
