2g rear camber adjustment.
geno414
440
4
Jan 13, 2011
Milwaukee, Wisconsin
Hi there I have a big problem my rear tires on my gsx are showing the wires on the inside tire closest to the hub inside . I have the " stm " camber kit the bolts I have the washers even threw the wheels and still have bad camber my car is on coil overs and I need some help took my car to fire stone and they said my adjustment bolt is frozen and wont move can some one help me . Because now I need new tires before they blow out
THe rear toe at -0.37 is what's killing your tires! Also the rear camber should come in. Oem specs are -1*40'+-30' and toe 3+-3 (.12+-.12). You should also try and get the front camber closer to the same number. Try to get to 0 for the front toe one side is 0.52! Ouch!! camber is even supposed to be close to 0* 20'+-30'! I would try to get both sides to 1.6 and zero out toe and your tires won't chew up at all, same for the back!
Ok cool thanks man looks like n order new toe arms ### mine are junk ill buy the megen ones and then have them fix the rest f the car thank you man!
