2G auto to manual- NLTS clutch wire HELP!
gob4sho89
215
Dec 31, 2006
Farmington Hill, Michigan
My 97 talon was once an auto, and now I want to use the nlts function in link V3. I have a switch on the clutch pedal, a connector and then 2 wires hanging off that connector which come from the switch. One wire is black with silver dots and the other wire is green with a black stripe and silver dots. I am not sure how to wire this up. From all of the searching I've done I am thinking put one wire to ground, the other to the ecu at pin #???. Then i'll have to invert the signal? A little help would be great, thanks!
