2G Auto to Manual
Illyjah
39
Aug 26, 2014
Toronto, ON, Canada
I'm converting to manual but I have no clutch pedal and I'm having a hard time finding one. Has anyone tried to fit in a clutch pedal assembly into the 2G that doesnt belong to an Eclipse at all? Like if I got a Subaru clutch pedal or something.
Also did the manual diffs come in non LSD?
It should be easy to find 2G MT clutch pedal assembly you need on ebay.
as I know clutch pedal assembly are the same between LSD/wout.
There are none on Ebay. I just checked. They are all brake pedals, the clutch pedals are not for the 2G eclipses.
Edit: Does the 420A work? I was wondering about the rear diffs, if they came in non LSD
If you check some of our vendors I'm sure one of them has what you need. I'd be surprised if miller imports doesnt have that. If not then see if the avenger or neon has a similar set up.
If you are doing the swap you are going to need both the manual transmission brake and clutch pedal, these can be taken from any 2g, RS/GS/GST/GSX they are all the same. As mustracetsi stated, you will need the correct cables for your engine type, cables from a non turbo can only be used on a non turbo, and turbo cables can only be used on a turbo, the transmissions are on different sides, thus the cables are different. I recommend you pay a visit to your local junkyard, with a quick google search I saw several in the Toronto area. As for the differential question I know that rear differentials came in both lsd and non-lsd.
well the 2G DSM's here are very rare to see, and I've been to the junkyards around here and I've only ever seen one Eagle Talon (that was years ago though) LOL but my search continues. Thank you for the tips though guys!
