pcnerd
- 0
- Jun 28, 2008
Kingsvlle,
Texas
Here's a quick short background on what's going on.
I have an Automatic 95 Eagle Talon TSI AWD. Motor went bad so a I purchased a motor off a Manual 97 Eclipse GST. I seperated the clutch and flywheel from the GST motor and swapped over the center Dowel to the GST motor from my Auto motor. I did not switch over the Plate that sits between the motor and tranny. "They looked the same" I mated the auto tranny to the block and dropped it all in.
After hooking everything back up and attempting to start the motor, the engine would turn over but you would hear a slight "CRRRK" sound like trying to start a car that's already on. The motor never did start because the starter stopped spinning the engine, it just went "CRRRK" and no more spinning.
So I took a look underneath and noticed the teeth on the torque converter were slightly eaten away.. it's very slight and just on the outside as if the starter isn't making proper contact and was only hitting the edge of the teeth.
My question to you all.. Is the mounting plate different for a M/T and A/T on a 2G?
is there is difference in thickness? is the hole for the starter slightly offset? Can I shim the starter somehow to make it work? Let me know..
Thanks,
Rudy
Thanks,
Rudy
