2g 7 bolts torque specs
microgalant
111
Aug 27, 2006
Aruba, South America
I'm about to built my engine I've eagle rods and arp main studs, can someone gives me the torque specs for the rod bolts and mainbolts using oil.
thanks
rods 45-48ftlbs
mains 55-65ftlbs
If you have arp studs, i believe the specs come with them or you can look them up on their website.
Also make sure you eliminate the balance shafts while you're in there.
I've use these bolts already , I don't remember where i've put the paper with the torque specs on it.
The mains i saw on the arp website are 85 ft lbs with 30wt oil, and using arp lube 70 ft lbs.
The rod I saw on this website Bolt Torque , I've the 2000 7/16 1.5 bolt, I'ts 43ft lbs, but doesn't say wich lubricant.
Am I right?
    • dsmmario
    • Detail
    • dsmmario
    • Canadian_CD9A
