2G 2G 7 bolts ARP L19 nut size
Torpedo
36
7
Mar 11, 2009
Taipei, Asia
Hi,
I just bought a set of ARP L19 Headstud kit for my 2G 7 bolts 99 Eclipse GSX from EXTREME PSI.
I did the search for the correct size of socket for nuts, but there are several answer for that.
in my case,
12mm 12 points socket is too small, can't fit.
13mm 12 points socket can fit, but a kind of loose. You can turn socket around 1/6 circle while socket sit on nut.
1/2" 12 points socket is perfectly fit.
I believe it is correct size for 7 bolts L19.
    • Sdcryan1
