2g 6bolt map sensor and power tr unit clean up
Recently I dropped another 6 bolt into a friends car after the previous 6 bolt installed developed rod knock. While at it i decided to install one of my own design CNC machined map sensor relocation pieces and clean up the wiring. It removed alot of unnecessary wiring from the engine harness to the firewall. The final product made it look like the 6 bolt engine came in the 2g from the assembly line. Let the before and after pictures tell the story.
The wiring is now alot more solid and clean. The map sensor relocater can be found at dsmparts.com and the moving of the wires only required the cutting and extending of 1 wire. the rest were just pulled back out of the main harness and rewrapped seperatly. Took about 30 minutes to complete. If you have any questions feel free to contact me
