- Year
- 1995
- Model/Trim
- Eagle Talon TSi AWD
- Transmission Type
- Manual
- Mods-Bolt-on
- Fuel and Induction
; Bosch 044 fuel pump
; -08AN stainless fuel feed line
; Aeromotive fuel pressure regulator
; FIC 1000cc injectors
; 3” turbo intake
; Forced Performance Red turbocharger
; Slowboy racing ‘race’ front mount and piping
; Greddy compressor bypass valve
; Cooling Mist methanol/water injection kit
; Custom 62.5mm throttle body
; Magnus Motorsports intake manifold
Exhaust
; Ported and polished exhaust manifold
; 8CM2 turbine housing
; Tial 40mm wastegate
; 1 5/8” external wastegate dump tube
; 3” custom o2 eliminator downpipe
; Apexi exhaust
- Mods-Engine
- ; G4CP 6 bolt engine block
; Wiseco 9:1 compression forged pistons 0.5mm oversized
; Eagle forged connecting rods
; King HP main and rod bearings
; ARP head studs
; Mitsubishi multi layer steal headgasket
; Ported and polished cylinder head
; EPN magnesium bronze valve guides
; EPN 1mm oversized stainless valves
; SI dual valve springs
; Manley titanium valve retainers
; Forced Performance FP3 camshafts
; Revised hydraulic lifters
; Long external Oil cooler with -08 stainless line
; Crank scrapper
; Galant VR-4 timing cover
; All new OEM components
; All new OEM gaskets
; Components balanced and resurfaced
; Jegs -10AN catch can
; Fluidlyne radiator
; SPAL radiator fan
; Magnecor spark plug wires
; Custom oil pan
; EGR and all emissions removed
; 90 turbo oil fil
- Mods-EMS & Logging
- Electronics
; DSMlink V2.5
; MSD-DIS2
; Innovate LC1 wideband
; GM 3bar MAP sensor
; Greddy turbo timer
; Beltronics RX75
; Autometer 52mm oil press, oil temp, boost/vac, pyro, o2 guages
; Integrated power inverter
; Viper 800esp security, remote lights, windows, hatch pop
; Sebring Auto dim and digital compass rearview mirror
; Eclipse Home link visor
; Trunk mounted optima battery
- Mods-Drivetrain
- Transaxle
; TRE built
; 11% taller 1st gear
; Front differential limited slip insert
; Center differential welded
; Heavy duty 3rd/4th gear set
; All New OEM gears, shift forks, syncro. assy.
; ACT pro-lite flywheel
; Segmented ASCO clutch disc
; ACT 2900 pressure plate
; Stainless clutch line
; Solid shift base/cable bushings
- Mods-Handling
- Driveline & Suspension
; Prothane polyurethane mounts
; Energy Suspension bushing kit
; Energy Suspension Sway arm bushings
; Eibach sport-line springs
; Tokico shocks
; Limited slip rear differential
; Enkei 18” wheels
; Rebuilt power steering pump
; Long power steering oil cooler
; Front & rear strut tower bars
Brakes
; New OEM ABS master cylinder
; Magnum stainless brake line
; Rebuilt twin piston front calipers
; Powerslot 12.5” front brake kit
; EBC green front brake pads
; Vented rear brake set up
- Parts Wishlist
- NAWS
- 1/4 Mile E/T
- 11.500
- 1/4 Mile MPH
- 125.000
- 1/8 Mile E/T
- 0.000
- 1/8 Mile MPH
- 0.000
- 60' Time
- 1.835
- Timeslip Video Link
- Watch Video
- Timeslip Details
- Track Name : Milan Dragway
Nitrous : No
Fuel Used : Pump gas
Vehicle Weight : FULL
Tires : Street Radials
Altitude : 900ft
Sponsored Car : no
- Dyno TQ
- 0.0 lb/ft
