2g 6 bolt swap
david1014
Mar 23, 2015
Des Plaines, Illinois
Hello guys,I just bought a 2g eclipse GSX with a 6 bolt swap and wanted to get more informed. Engine wise I understand that I would need 1g parts if I want to replace anything, but also are there any 2g parts that will also fit on the 6 bolt swap? Sorry if I sound dumb but I just want to get as much info as possible before I do anything, again I'm new to do this
First of all, make sure that it is a full 6 bolt swap!
Check the head. Look at the CAS. http://www.roadraceengineering.com/1gcasin2g.htm
Check the block. Look at the oil pan. http://www.vfaq.com/mods/early-late-engine.html
Check the intake/throttle body. You can have a 6 bolt motor with a 2g intake. A 2g will have the MDP sensor bolted on.
And it depends what kind of parts you are talking about. If you want to know specifically just ask. I have a 2g with a 6 bolt swap.
Good links, also to add: http://www.dsmtuners.com/threads/dsm-maintenance-guide.476550/
Do this and check all this as well!!
Thanks guys! I checked the CAS and oil pan like and it looks like a 6 bolt. As of now I am planning on replacing spark plugs and wires as well as distributor cap and rotor. So I would have to get spark plugs for a 6 bolt. Also a basic oil change. Any suggestions for maintenance?
The maintenance guide is your lifeline, but off the top of my head I can think of replacing all belts, hoses, check and make sure you don't have bare wires hanging anywhere, then you can do other basic stuff like brakes and suspension if its bouncy.
DSM's love to leak. If you find a leak, fix it!
Thanks I appreciate the help guys, so now that I know it is a full 6 bolt I would need earlier model spark plug wires correct? I am planning to also get NGK bpr6es spark plugs
The wires for any dsm are the same other than the fact that wire set from a 1g to a 2g are different lengths. Other than that they are the same. I don't remember which is the longer of the two but that's the only difference.
Hey I have a question? So if I need a new alternator do I need a 1g or 2g alternator?
Another question! So I noticed a crack on my exhaust manifold and I am planning on replacing it, would I need a 1g or 2g? I am just looking to replace it with a stock one
Dsms leaks are a real headache I had my oil burning up on my timing belt so I had no clue until the hot oil blew my belt and bent a bunch of valves so pull that timing cover and check for oil stains ETC and belt quality
1G manifolds are prone to cracking so they are usually swapped out with the 2G or E3 manifold as they are all interchangeable. You could also get a FP manifold which would be the best option performance wise and they run around $175 if you are interested. http://store.forcedperformance.net/PROD/EMFPRace.html They have rave reviews, I dont have one (yet) but everyone seems to love them. I personally have a 2G manifold and have no complaints really.
Synthetek, wouldn't this be a good time to do a Galant (plug and play) or Saturn alternator swap? When I replaced mine, which is a 1G, I put a 96 (I believe) Galant alternator on for more amperage. Since I don't own a 2G (son does) I didn't know if the OP could do the same swap. And by the way, I love my FP manifold also. Looks kinda stock but performs and SEALS great! I had a problem with a tubular manifold leaking at the flange so I pitched it and went with the FP.
Would the 2g manifold fit fine or do I need to get anything to to adjust it??
Another question? So I noticed that it leaks oil through that line(new to this so idk what it is) is there supposed to be a cover or a tube or something there? How can I cover it?
Which line? The nipple without anything on it should have a line going back to the intake tube, pre turbo.
Thanks Calan. Yes for proper operation it should have a hose from the nipple to a barb on the intake tube, pre turbo, to create vacuum to suck out the nasty fumes that are made in the motor when the pcv valve has positive pressure (during boost) and isn't sucking them out to reburn to say it as simple as I can. When you're under vacuum in the motor, the pcv valve will draw the fumes into the intake manifold and that nipple will supply fresh filtered air.
  • For sale 1g Assortment of New, Used, and Unobtanium Parts
    All good stuff. Will sell individually or lot sale.
    • 8716valver
  • For sale 2g 95-98 Talon air bag.
    2g Talon airbag. Really good condition. Can ship ups ground. Message 702-741-6987
  • For sale Injen Intake System
    Good condition used Injen Intake System for Turbo DSMs
    • kyler021
  • For sale 1g 1G Driver & Passenger Door Jam Seals
    1G Driver & Passenger Door Jam Seals $50 + shipping & paypal fees* these are the door jam...
