255 Walboro or Supra fuel pump
what the denso consumes power or the walbro?
Which brand should I get when i get a 190... I think im going with 190
until I get money for a afpr and then ill get a supra pump and rewire it.
The supra pumps nor the 190s are noisy right?
The Supra pump consumes more power - Denso 260 LPH pump, part number 195130-1020
Walbro
Then why get a 190 now? Just save up and buy the whole thing.
Supra pumps are not noisy, the 190s are less noiser than the 255.
i dont have money for a afpr and all my money is drained because of my engine build up, and plus I need new struts all the way around and new tie rods. So im pretty shot on money. Id love to start off with the best pump but the fact of me needing a afpr for the 255 or supra pump killed the whole factor.
I am currently having think a lean problem my ltrims lo are 8 and mid are 12.5 think that is lean as you can go.
I have a supra tt pump ,new 6 an line and new 6 an billet filter, new FIC 950s and sx afpr.
I try to set the reg to 43 line off and when I connect line it only seems to drop it like 3 psi not 10 like thought it should.I have liquid gauge.
Also the supra pump while it fits perfect in a 1g it don't fit worth crap in a 2g.It has to go in crooked and I even tried dremeling this plastic thing that it was hitting on.
I am not very comfortable with the way it sits in there and wondering now if its causing some of my lean problems but not being in there straight.
So the 255hp is stupid loud? The supra is quiet very quiet but like said wish it fit better.
Anyone had problems with a supra pump in a 2g?
well thats good to know it will fit perfect in a 1g for my case , and also since you say its quiet... Im not sure if that is your lean problem because of the pump sitting that way. I think there was a thread on here like a week ago about supra pumps you should check that out maybe will tell you what you need to know.
if u goto www.toyotanation.com you might be able to talk one of the guys into selling their pump to you, but the problem with trying to get a supra fuel pump off one of these guys is all the guys with turbo mr2's snatch them up first.
I know this is an old thread but I didn't want to open up a new one for this.
Drivewire.com has the 93-98 supra turbo fuel pump for $221.00 and it is the OEM Denso one. Brand new.
